Drive shaft Length
scatpakman
Osseo, MN
Looking to get a driveshaft made up for my 68 Dart. low deck, 727, 8.75 489case, with 1350 yoke. how do I measure it to assure a correct length? Or does anyone have the measurements? Thanks.
until you have all those parts bolted in the car none of it matters. at minimum you need to install the block, trans housing and rearend with what ever suspension you're going to run. get the car close to finished weight and sitting on the wheels at ride height. then call the driveshaft place and ask them how they want it measured
