drum to disc brakes
gclintonmopars
Shreveport La
Changing from drum brakes to Kelsey Hayes disc brakes will I need to change the lower A arm or is lower ball joint the same any help appreciated Gary
If you have the proper disc brake ball joint, it will fit into the lower control arm...
Did it on a 71 Valiant 4 door....
