[WANTED] Dual snorkel hood scoop for my duster !!!
Year? 71 72 flat bottom. 73 curved bottom.
Is that correct..? 71 Hood isn't flat.. I thought it would take the tapered bottom. 72 Demon takes the flat bottom.. That's just what I thought. Correct me if I'm wrong, because I have one of each I'll be selling and want to make sure of the applications.
70, 71 demon and dart hoods are smooth centre. Believe 72 also. In 73 and up, rib runs down the centre of the hood.
Right...but he was asking for one for his 71 DUSTER.. I don't think those hoods are flat / smooth / SLIGHT ridge down center. I think there's a prominate raised center on the 71 Duster hood. I could be wrong..
My bad. I'm going to have to look again at my duster hoods.
No biggie.. I didn't even know there were 2 different snorkel scoops until I bought the wrong one for my Demon and it didn't sit right.. That's how I found out. There might even be some modification that needs to be done if putting on the Duster. Never made for the Duster...just 72 Demon and Dart Sports.. Again, I could be wrong.
I was thinking the same thing about snorkel on duster...not offered. Found out about difference same way you did. Duster has 2 ribs shaped like tapered wedge. Scoop would need modifying.
my 72 duster with ridge on the hood had factory snorkle scoop, original owner got it installed at dealership, canada if that makes a difference. check for a 72 duster scoop maybe.classic industries sells them also
This is how it looks when done correctly
