Duster Doors interchangeable ?
  • Thread starter Thread starter EP87
  • Start date Start date
E
EP87
Guest
Hi Stripped my 70 Dusters drivers side door today and found out its got a crappy
patch and to much rust to deal with. Just wondering what other year or models are the same.
Thanks
Well any Duster,Demon, or Dart Sport door will bolt up and work. But like
greg340 said. 73 and up are different on the inside. Instead of the upper inner part of the door being metal on 73 qnd up. They have a full langth plastic door panel. And the door handle is different and in a different spot.
The Demon came with a Swinger door on it, less the vent window frame. It fit the hinges but won't work in the application. The hardtops and 2 dr sedans have a different corner where the A-pillar and the roof join.
Should work. I have a 75 Duster with a 72 Demon door on it.
If your going to install a standard 6 point(or more) roll bar the 73 and up doors come in handy and look cleaner, because the inner door handle is up higher and out of the way of the side bars.
