Duster Interior Door Badge
TurboGLH
CT
These are available for around $30, so it's debatable if they're worth printing yourself unless you have a printer with multi-material support, and you have black/white in ASA already.
There are three versions, because.....I made changes that seemed to make sense. The first one is just like factory, the second is the same except it doesn't have a recess on the back (makes it easier to remove support) the third one is the easiest to print, but the most fragile. It has separate pins, so the parts print flat and require little/no support. The downside is the union between badge and pin.
Note: This requires a 0.4 or smaller nozzle, which is typical on most printers. If you've upgraded to a larger nozzle for faster speeds or to utilize filaments with carbon fiber or fiber glass, the "Duster" text will not print, the features are too small.
Free for personal use or remixing, no commercial use or resale allowed.
