[SOLD] Dynabrade 6” Dynorbital-Spirit Random Orbital Sander With Discs $120
JD Erisman
Alaska
Dynabrade 6” Dynorbital-Spirit Random Orbital Sander with sanding discs included, model 21035. I bought this new several years ago and used it on my ‘67 Barracuda when I did the body and paint, that is the only project where I have used it. I haven’t loaned it to anyone. Very good condition. Oiled per instructions. Model 21035 was replaced by 59025 though I cannot see the difference, other than color, when I read the description, which I pasted below. Made in the USA, a high quality piece.
The sanding discs are sticky-back and vary in grit from 40 to 1000. $120 for all of it, that price includes the shipping cost to anywhere in the USA. In other words, shipping is included.
  • Includes low profile, premium urethane weight-mated sanding pad. Optional vacuum conversion kits are available to easily convert non-vacuum tool to self-generated vacuum tool or central vacuum tool. Grey lever identifies 3/16" (5 mm) dia. orbit, used for general sanding.
  • Drop-In Motor available (sold separately) to reduce costly down-time associated with routine maintenance. More Power - True 12,000 RPM air motor. Floating rotor utilizes five blades, producing more usable power (.25 hp/186 W). High-strength, composite rotor has better lubricating qualities, allowing blades to last longer. Less air (14 SCFM/396 LPM) is used more efficiently to maintain maximum power.
  • Comfort Platform provides additional hand and wrist support, further enhancing operator comfort. Also offers increased protection against cold air exhaust. (NOTE: Comfort Platform is removable.) Order 59330 Comfort Platform (U.S. Patent No. D610,428) separately, to install on existing tools!
  • Throttle lever recesses into housing grip when depressed, eliminating pressure-point on operator's palm. Dynorbital-Spirit lever is made from composite material to insulate against cold air. Lever is color-coded to designate tool orbit. Easy maintenance and vacuum conversion. Muffler elements are easily changed for convenient maintenance. Low Sound Levels. Muffling system reduces exhaust sound levels.
  • Speed Control allows thumb-control regulating of tool speed. Lighter air-motor assembly, ideal for vertical and overhead sanding applications. Precision one-piece motor shaft and counterbalance. High-quality Double Row Pad Bearing, protected by unique V-Seal, improves bearing life and ensures reduced vibration. Perfectly-balanced, weight-mated sanding pad with one-piece hub design. Dynabrade premium urethane pads offer smoother operating performance and minimal vibration. $207.42
