[SOLD] Dynomax Ultraflo #17220
12many
SC
Part# 17220 stainless 3” ID in/out center/center. One of the best flowing mufflers available.
Case measures 14”x9.75”x4.75” and the overall length of the in/out pipes is 19” These have not even 500 miles on them, one cracked at the lengthwise seam. The other is fine. I used the band style clamps so the tubes are not dimpled. Will slide right on your 3” OD pipes. These mufflers IMO sound awesome. Simple weld and you’re good to go. $50+ shipping or you pickup Box will be 20x12x11 and weight about 25 lbs coming from zip code 29302 if you’re shopping rates.
