E-85 help
kocuda
Portage, WI
I hear some of you guys are running E-85 fuel. Its readily availble here everywhere!
What mods need to be done to use it?
Will it work with 12.5 to 1 compression.
Help an old dog understand!:?
i run it in my dart,and run low 10s,6.40s in 1/8 mile.it does make it run cooler,and the fuel is like alky,its 3.19 gal here,beets 7-8 dollars a gallon for race gas
What engine mods? Does it eat up the rubber parts in the carb?
I'm really searching for info on its use.
e-85 is good if you use it all the time,but for something that sits around a while or just gets used a few times a year,it will eat up stuff,if you dont use it much,drain the carb
