srixon4406
TURBO TOAD
As most of you are aware i decided to change my 62 valiant from a turbo slant six to a boosted stroker big block.
Ive sold off all the small parts and have just the turbo setup left
1.stainless steel thick wall turbo header with 1/2 header flanges.
2.390 hp e85 blow thru carb with vent tube extension built and flow tested by eric at horsepower invitations with his billet metering blocks and thrid circuit fuel delivery setup and annualar boosters.
3.pte6262 duel ball bearing t4 .58ar exhaust housing this turbo has low hours and under 2000 miles on it. If you guys know anything about turbos this is the grand daddy of them all and retails for around $1700
4.2.5 inch intercooler piping and couplers and T bolt clamps
5.ebay 44mm wastegate for the turbo header
Im going to keep my blow off valve so one will need to be purchased
Also i have a Oring cutter and im willing to loan it to whoever decided to buy this setup
All parts are located 49234
Im looking to get $2000 plus shipping for the whole setup as stated before parts are located 49234
