[FOR SALE] Early A Emergency Flasher Harness
65 Dartman
1 of None 65 Dart Sedan Delivery
Strasburg, VA
here is an Mopar OEM emergency flasher harness of I believe 65 or 66 vintage that I was going to use in my 65 Dart (using a modified Mirada harness with the emergency flasher components built in).
I did replace the hot wire from the flasher. I am not sure why the original wiring had an inline fuse as the wire coming out of the fuse was piggybacked to a hot fuse in the fuse box It is pretty much plug and play as far as the electrical connectors go - unplug the steering column harness, plug in the emergency harness and then piggyback the hot wire to a hot in the fuse box. You'll need to drill the appropriate side mounting hole somewhere in the dash. $40 shipped to any US Zip Code.
