[WANTED] Early A floor shifter parts
Syleng1
Karma is real and Life is short...
North Franklin, CT
So I am looking for two specific parts for a 1966 Plymouth Barracuda.
1) transmission tail shaft bracket and bushing- A-904.
This holds the bottom of the coffin style center console automatic floor shift pivot rod (that passes thru the floor tunnel) in place to the bottom of the transmission tail shaft using 2 studs and nuts. I need that formed steel plate, bushing and nuts if you will sell them.
2) I need the shifter linkage that connects the above mentioned automatic floor shift pivot rod to the arm on the PNRN321 lever on the transmission side.
Retaining clips as well.
During the rebuild I marked every part and cataloged each one in a box with a master list.... these two are missing. Found all outher parts but these two are not there.
Any help would be awesome. Sorry I don’t have pictures.
Joe
On #2 are you looking for the trans rod that goes from the vertical down through the floor torque shaft to the trans valve body lever?
If anyone knows where to buy this new please also feel free to chime in.
Thanks-
Joe
