[SOLD] Early Slant Six with 4 bbl and headers
MidnightSwinger
Woodland CA
This was a runner in a 65 D100, intake and headers were removed when the motor was pulled, and then loosely reinstalled. I recommend a new gasket.
Motor was rebuilt .020 with a RV cam, maybe 20,000 miles on the rebuild. Offy 4 bbl,Edelbrock 500 carb,Clifford long tube headers. Motor didn’t leak, even the rear main!Crank is drilled for manual transmission. The oil pan is a junker just on there to keep it covered. You will need a proper truck pan to install in a truck.
$800 located in Woodland CA 95695
