[FOR SALE] Early style 727 front servos
fshd4it
Squid inc
Winock WA
Your choice, 45#/25# or 45#/45# $40 each plus shipping, probably about $10 to the lower 48.
Is one spring set better than the other?? Does it just release the front band sooner with stronger springs, reducing shift overlap?
They used different spring combinations for different transmission applications, spring count in the direct clutch, lever ratio, etc... so yeah, you can dial in band apply/release rates.
