Eddy 60779 heads
dusterforever
North Central Texas
Can someone please post a picture or tell me what alternator bracket to use with the 60779 eddy heads. My car is a 73 duster with a 77 LA 360 block. Also my car has power steering and the pump and bracket came with the car but is mounted near top of engine on drivers side...not sure this is correct bracket and pump either. Any place to buy new brackets? Thanks...Tim
R/T Specialties has the stock alt. brackets:
http://rtspecialties.net/
I believe you use the stock brackets that bolt to the water pump since water pump to alternator relationship is not changed. I believe the issue is the spacer between the head and the alternator must be shortened.
