For sale is a new Edelbrock Thunder Series AVS carburetor in its original box. I took it out for photos. My plans changed and will not be using this carb. The specs of the carburetor are below from Edelbrock.
The Edelbrock 1806 Thunder Series AVS 650 CFM electric choke carburetor has been designed and calibrated to deliver optimum street performance. Several characteristics make the 1806 Thunder Series AVS 650 CFM electric choke carburetor an outstanding street performer. The first one is that metering rods are utilized to transition between circuits. The carburetor is unaffected by engine backfires, which means that there are no power valves to blow out, and the rods can be changed in seconds without carburetor removal or fuel draining. Secondly, the carburetor has the unique ability to "hold a tune", so once it is tuned, the carburetor stay’s tuned. What this means to you is that compared to other carburetors, the performance remains consistent and the calibration stays unchanged. The third characteristic is the primary and secondary booster clusters that are utilized offer the most accurate and up-to-date calibration available for today's fuels and octane levels. Fourth the unique Thunder Series' Qwik-Tune Secondary Air Valve allows for limitless calibration of the secondary circuit with simple hand tools while on your vehicle. It's quick. It's simple. It's effective. It can be easily adjusted - in seconds - to suit your application... no extra parts required to achieve optimum performance. Simply put the Edelbrock 1806 Thunder Series AVS 650 CFM electric choke carburetor is undeniably the most innovative and dependable street performance carburetor available today.
New price is $368. I will sell this new carburetor for $300 shipped in the lower 48 states. I will ship internationally for the additional cost if any.
