[SOLD] Edelbrock Torker 383
RustyRatRod
Caput villa stultus
Georgia
Excellent condition Edelbrock Torker 383. Mopar Muscle did a big shootout with intakes and this one outperformed a lot of otherwise supposedly better intakes, not giving up nearly what you would think on the bottom end a single plane would. Great addition for any low deck build. I blasted it, blew it off, cleaned it with denatured alcohol sprayed if with 2000* VHT primer, then 2000* VHT aluminum and finally with 2000* VHT clear. It was marked with dye in prep for porting but no porting was done. It is pristine and original. All threaded holes excellent. I will take 150 shipped to the lower 48. You will need to bear with me because it may take Kitty a few days to find a suitable box for shipment. Located in middle Georgia.
