[FOR SALE] Edelbrock Torker II 340 Intake
slant six
Do More With Less
IRWIN
Here is an Edelbrock Torker II Intake. I cleaned it up a bit, I put in in the bead blaster and gave it a nice shine. It is ready for paint or you could leave it with the satin finish from the bead blasting cabinet.
Asking $300 Plus Shipping from 15642, PA to you.
It arrived to me with a broken off bolt in the larger of the 2 thermostat housing bolt patterns. (1978-older I believe on the LA Engines)
I repaired the broken bolt properly by using an endmill bit to remove the old broken bolt. Then I used a thermostat housing to locate the hole and installed a helicoil where the snapped off bolt was. The bolt lines up properly as it should - no hand drill fuddy duddy work here.... been threre, done that, and I never liked the results.
Pictures of the repair process:
Pictures of the intake:
