[FOR SALE] Edelbrock Victor MW bare heads
Matts440
Nampa, Idaho
Located in Nampa Idaho
Selling off my 77939 bare max wedge heads, they have been CNC ported by cncport.com, they used these heads for the program. Asking $2200 plus shipping. Heads new are about $1300 and the CNC is $1400.
What size are the chambers?
Victor Max Wedge head with 75cc chamber size, 290cc port size, 2.200"/1.810" valve size
Intake ports are machined to match Max Wedge intake manifolds for B and RB competition big-block Chryslers Intake ports are raised .650", exhaust ports are raised .250" for improved flow The intake flange is extended .950" to eliminate the need for intake spacer plates Standard 15-degree valve angles with 290cc intake and 100cc exhaust ports Exhaust flange is extended .300" from stock (same as Mopar Stage 6) featuring dry exhaust bolt holes with Helicoil® thread inserts Raised valve cover rails and dual quench 75cc combustion chambers Sold without springs or retainers; use recommended springs to match your cam
Stock they accept 2.20, but you can put in the 2.25. Its been a while I can measure the intake if you like.
@LO23M8B
Yes they are opened to accommodate 2.25" where stock is the 2.20.
2.25 at outer edge 2.00 in the throat
