Electrical Cleaners?
shovhd
Courtenay, BC
Does anyone know of a product that you can spray on your circuit boards and connector blocks to clean up corrosion, etc? If not, how did you clean yours up?
Thanks
Nigel
Get some electric contact cleaner or in a pinch you can use brake cleaner.
Most auto parts stores carry them.
For bulb contacts I use a brass gun bore brush on a drill slowly. For others that I can physically touch I use fine sandpaper strips or emery cloth. For stuff that I can't see or reach I use electrical contact cleaner spray, it's safe to use on electric motors, contacts, etc.. and leaves a very tiny bit of contact lubricant to help prevent corrosion. The can I have I picked up for around $7-8 at the parts store.
