Energy suspension sway bar brackets
burdar
Owen's Dad
Iowa
Are the instructions wrong that come with these brackets? I've got a K-member out of a 72 Demon that's going in my 68 Dart. The instructions show the bracket bolting onto the K using two existing holes. The way they show to bolt it up, the holes don't line up and the bracket is at a weird angle.
If I turn the bracket and use a different hole then the instructions say, the holes line up and the bracket is at a better angle. Half of the bracket is sticking out the front of the K though. It doesn't make sence. I'll post pics shortly.
72 and older K frame/member the sway bar sit in front of the k frame.
Yes I know. The instructions must not be showing an A-body. I found a picture while doing a google search. It shows the brackets mounted up opposite of how the instructions say to mount them. The wife is on the computer right now. I'm on the iPad. Pictures will have to wait a little bit.
