[SOLD] Erson solid cam/lifters/rockers/pushrods
1966Post
Wisconsin
Erson solid camshaft RV10M this is a used low mile cam/lifters set with banana groove 273 rocker arm set with mechanical pushrods
Cam specs:
Erson Cams 8000 Old 3rd Street Rd Louisville, KY 40214 PH: 800-641-7920 Part No.: E470301 Grind: RV10M Intake RV10M Exhaust 111+4 Lobe Separation Angle Overlap: 32 Intake Opens: 20 Exhaust Closes: 12 Intake Closes: 54 Exhaust Opens: 62 Running Clearance: 0.022 0.022 [Hot] Valve Lift (Int / Exh): 0.435 0.435 Duration (Int / Exh): 254 254 Checking Figures @ .050" Tappet Rise Overlap: -12 Intake Opens: -2 Exhaust Closes: -10 Intake Closes: 32 Exhaust Opens: 40 Duration Intake: 210 Duration Exhaust: 210 Lobe Lift Intake: 0.290 Lobe Lift Exhaust: 0.290 Intake Center Line: 107 Rocker Arm Ratio: 1.50 /1
Made back when they had great cam blanks and good metallurgy
Lifter are in order and marked according
Would be a great 273/318 Street cam or truck cam for a 318/360 which was my original plan
I ran across a roller engine so no longer have need.
$275 for all plus actual shipping thru Pirate Ship
Thanks FABO
Cam specs:
Made back when they had great cam blanks and goo metallurgy
Thanks FABO
View attachment 1716465703View attachment 1716465704View attachment 1716465705
Can you post pics of the lifter faces please.
oh and "Goo" ...
is that missing a "d" or a "k"?
It's both. Have to be polically correct these days..
Fixed .. and here is the requested picture. I have a very old set of new comp 821-16 lifters that was part of an Estate sale deal I got years ago. They had surface rust and I cleaned them a bit sprayed them with with WD40 and haven't touched them since. They can be included for $20 extra. Their faces "rock" when you butt them up against each other I'm sure they were never used but again need some cleaning up
