gregpurcell
Greg Purcell
This is a rare used set of 340/360 factory motor mount brackets needed to swap from a 318 to a 340/360 in a 67-72 A body. NOTE: These are NOT "conversion mounts". Your car MUST have the v8 K frame to use this setup.
These are the brackets that you CAN'T "put a shim in the 318 piece and use it" because it's actually missing an ear necessary to bolt to the 340 left side tabs.
I also have a used set of the rubber motor mounts that look like they have some life left in them.
If you are planning a 340/360 swap into your 67-72 A body anytime in the future, grab these NOW! They are hard to find when you really need them.
Located in Savannah, GA $100 shipped in the US.
