Fan shroud question
Kenflo
Saint Albert
On a 1973 340 26” radiator the fan shroud part #3673820 seems to be very hard to find. Will the readily available reproduction #2998326 shroud fit? The reproduction is listed as B & E body big block. There are also other 26” reproduction shrouds being made just wondering if any will fit the a body small block?
Technically, at least on a bodies, the centerline of the water pump SB and BB are on the same axis
