Fender removal help
ryansiki
PG, BC, CANADA
How many bolts hold the fender on, and where are they located? My car is a 75' Valiant. All help in appreciated greatly....
There are 2 bolts at the bottom rear of the fender behind the wheel, one bolt is hidden up at the top corner where the fender meets the door. You will need to remove the rear splash shield to get access to this one, and use a looong extension and a deep well, as it is a nut on a long threaded locator bolt. There are also going to be some bolted to the radiator support, and though I'm not completely familiar with the 75 Valiant, the lower grill splash pan might be bolted to the fenders. You may also want to remove the front splash shields in case they are hiding the turn indicator plug ins. And of course the bolts along the inner fender rail. Good luck with your project, Geof
