Fender tag? Decoding it?
Ken_B
Rocky Point, WA
I would like to decode my fender tag on my Plymouth, any of you experts up to it? Thanks in advance.
VL41:
Plymouth Valiant,Duster
Low
4 Door Sedan
C2R: 225 110HP(net) 1-1BBL 6 CYL
1972
Windsor, ONT, CAN
319552: Sequence number
E24: 225 cid 1 barrel 6 Cylinder 145hp
D34: Light Duty Automatic Transmission
GY4: Gold Exterior Color
C4F6: Trim - Charger, Vinyl Split Bench Seat, Green
GF7: Sherwood Green Poly Int. Door Frames
515: Build Date: May 15
517289: Order number
V14: Full Vinyl Top, Unknown color
U: USA Specifications
22: Unknown
B51: Power Brakes
C12: Unknown
F11: 46 Amp Alternator (std with AC)
S33: Unknown
H51: Air Conditioning with Heater
L31: Hood/Fender Mounted Turn Signals
M21: Roof drip rail moldings
M25: Wide sill moldings
M38: Decklid Finish Panel Moldings
R11: Radio Solid State AM (2 Watts)
V5X: Body Side Stripes, Black
END: End of Sales Codes
your car is nearly identical to mine. Welcome to the 72' valiant club.
These are mine, both decoding courtesy of mymopar.com.
VL41:
Low
4 Door Sedan
1972
Windsor, ONT, CAN
287278: Sequence number
C4Y3: Trim - Charger, Vinyl Split Bench Seat, Gold
GY4: Gold Int. Door Frames
414: Build Date: April 14
C38662: Order number
V1X: Full Vinyl Top, Black
C: Canada Specifications
22: Unknown
B51: Power Brakes
C12: Unknown
F16: Unknown
G33: LH Remote Racing Mirror
Line 1...
E24=225 6 cylinder 1 bbl.
D34= Std Duty trans
VL41= V=Valiant, L=Low trim class, 41= 4 door
C2R= C= 225 6 cyl., 2+ 1972 model year, R=Windsor Ont. plant
319552= Sequential build number
Line 2...
GY4= Light Gold
C4F6= C=Custom, 4=Vinyl split bench w/center armrest, F6= Green
GF7=upper door color=Green
515 and 517289= 515=order date May 15, 517289= order number
Line 3...
V1F= V1 is full vinyl roof, F=Green
U=I'm not sure of
22= 22" radiator
B51=Power Brakes
C12=Federal Restraint
F11=50 amp alternator
Line 4...
G33=LH outside mirror/Remote/Chrome/Con
H51=A/C with front heater
L31=Turn signal light/fender/hood
M21=Drip trough moulding
M25=Body sill moulding
M38= Don't have this code in my book
Line 5...
R11=AM Music master radio-2 watt
V5x=Body side protective moulding/black
End= end of tag
Hope this helps, Geof
Very cool! thanks guys! Its a fairly well optioned Valiant. Wow, thats uncanny the cars are so similar.
