Fender Tag Replacements
Odin
Terre Haute, IN
Who do you guys like for making replacement Fender Tags? (A.G. Backeast, MMC Detroit, etc.)
I bought an old Mopar a year ago. The dash pad is cracked like the Grand Canyon and the fender tag is missing. The dash VIN tag matches the numbers on the cowl and radiator mount and body. I also found the build sheet under the rear seat springs, which also matches all the numbers. There were some changes made by prior owner(s) including replacing the flat hood with an RT hood , swapping out the original 318 with a 440, and removing the vinyl roof. When compared to the build sheet, most or all of the other codes match items still on or in the car. I want to make replacement Fender Tags with the original codes to match the build sheet.
Please no comments about how replacement fender tags are counterfeit etc. I am making them to match the build sheet, not to pretend the car came with something it did not.
