Flashers activate in reverse !
mbaird
mbaird
Boise, Id
So I have sorted out my no start and melting wire issue but now my flashers go on when I put the car in reverse ! Even if I disconnect the reverse switch connector at the bulkhead .
I have double checked the turn signal switch terminal for correct wiring ,
All my lights worked properly before .
I changed something in my quest ... what did I do ? Lol
At least I didnt wire my horn to my brake light switch .
LOL. This is great entertainment. Hope you don’t mind my chuckle. It think it would have been cool to have the flashers go off every time you go into reverse. You may have set a trend!
WOW, there's a "HUGE" difference between a UPS truck & an A body MOPAR... LMAO
