I have a 1960 dart that needs new floor pans. The issue is the gas pedal mount if rusted and needs to be replaced with the floor. The pedal is mounted to a raised area of the floor and my pans are just flat sheet metal. Does anybody have an easy way to raise the pedal to mount it as original. I had thought about building a raised area on top of the floor pan and mounting like that but am not sure the best way to do it. I dont know how it would work if i mounted it to the flat floor but I dont think it would work well.
Thanks for any suggestions
