[WANTED] FLOORPAN
look, all lower case ... i'm whispering.
try @crackedback ... he has mostly dart sheetmetal but may have what your looking for
Ok, thanx I'll check into it. Look, is this better. Didn't realize folks were so sensitive to upper case noise, especially on a motor head forum. Dart floor pans, believe it or not are different dimensions than cuda's and Dusters.......according to the folks at AMD. That's why they have different part numbers.
GL
Because darts have a longer wheelbase.
Just get a pan for barracuda or valiant.
THANX, i'M AWARE OF THESE BUT THEY ARE STAMPED FROM 1970 DUSTERS. I'M TRYING TO GET THE CORRECT ONES IF SOMEONE WHO MAY BE HOARDING WILL GIVE IT UP ($$). I'LL GO TO THOSE IF I DON'T LOCATE AN OEM WHEN I'M READY TO START THE RESTO IN JUNE .
