Flywheel 122 Tooth
I would think so, but you would need to ask them. One off part typically cost quite a bit more in comparison to stocking part #'s.
Great, Thank you I will check with them. I understand about the one off parts.
I am used to that all the time here in high performance slant 6 land.
Hello Dan, I emailed RAM about a month ago and Have not gotten a response. If you will be at Carlisle, can I speak to you more about this Project? I cannot seem to locate a Phone # for ram, Just email links on their Website.
Thank you for any help or contacts you may be able to offer.
I am looking for something like the Flywheel on the Right in the photo below.
Yes, I'll be at Carlisle buying. Send me an email through my website, and I'll put you in contact with Ram.
Hello Dan, Will Ram Make a 122 Tooth Slant Six Flywheel in Aluminum with the ability to Mount a 10" Clutch Disc?
I had Wilcap make me one a while back and it had 2 Pressure plate drill patterns on it for the Borg and Beck 9.25"/10". and for the Ford /Mazda 10 " diaphragm pressure plate drill pattern, but they could only manufacture it with the 9 1/2" Steel ring for the clutch disc so I cannot use it with 10" clutches.
I have also contacted fidanza and about this project they will not respond to me, and looking at the reviews on google about them, I should propbabluy just move on and not even involve them in my project.
Thank you for any insight you may have.
Thank you Dan for your help.
I was able to get in touch with Mike over the summer at RAM. It took a while but I was able to get 3 of the Semi-Custom Slant 6 Billet AL Flywheels produced for my Slant 6 Road Racing Setups and or Future projects.
Specifications and Pictures below:
  • 122 Tooth
  • Fits in Stock Slant 6 Bell Housings Such as:
    • 3 Speed AL
    • 4 Speed '64-'66 Cast Iron
    • 4 Speed 833 OD Multi-pattern 1975-87 AL.
  • Large Bore Crank Pocket (easily adapted to 1960-1967 Cranks with an annular adapter that I have made here locally).
  • Weighs 10.1 - 10.09#
  • Can Accept a Ø9.25" to 10" clutch disc
  • RAM has my Order # if anyone else would be interested and willing to shell out the ca$h. They can make these with 3 Pressure plate patterns:
    • I had 3 flywheels made in different configurations. Can be made with 2 patterns on a single flywheel.
  • Available Pressure Plate Bolt Patterns:
    • Stock Borg and Beck Slant 6 9.25" / 10"
    • Ford / Mazda 10" Diaphragm (2001-2011 For d Ranger with 4.0 V6)
    • RAM 9.5" Pressure Plate
Some Pictures:
Weight comparison of a 2128290 stock large crank pocket 122T Flywheel:
And a second one: - same P/N; different supplier.
