[FOR SALE] (( SOLD)) FOR SALE 75 HANG 10,383 BIG BLOCK.
Ricer
Member
Canada
Rating - 0%
0   0   0
FOR SALE, 1975 HANG 10. $19,500 USD. Originally had a 318, now has a 383 big block with a functional ram charger air cleaner set up. The car runs and drives awesome, has a 276 sur-grip cruises down the highway at 75 MPH, 2300 Rpm. Very solid car, floors and frame are excellent, the only paint flaws are a couple of paint blisters on the quarters just behind the doors both sides. I have done a lot of work on this car in the last couple of years. The car is located in Eastern Canada.
Where in eastern Canada ? Did you restore it or is it mostly original other than engine ? Looks nice.
Looks like New Brunswick plates ?
Vehicle is in New Brunswick, Car was painted about 7 years ago, really good shape. Runs and drives excellent.
So we went from eastern Canada to New Brunswick. Maybe a city, town or village?
Anything like power steering, brakes other options. I'm interested ??? More info would be helpful.
Sorry, the car is in Oromocto, New Brunswick, its about 15 mins from Fredericton. The car has power steering and power brakes. New brake booster and master cylinder were added after the pic was taken.
I realized i left out lots of info, sorry. It has a 8 3/4 sur grip with 2.76 gear, cruises down the Trans Canada 75 MPH and only 2400 RPM. 15 inch rims with 255 on the rear , will have to check front.
Last winter I replaced: Rear brake shoes, two new wheel cylinders, brake lines, inner axle seals. New fuel pump (Holley), front flex lines, new brake pads, upper and lower bump stops, upper control arm bushings, 4 new ball joints, new brake prop. valve. New rubber trunk seal, new rubber door seals, up graded headlights to H4 LED. Removed gage cluster cleaned painted gage needles, touch up dash paint. New plugs, fuel filter.
Was this originally a Hang 10 ?
I thought all hang tens had sunroofs.
