[FOR SALE] For sale/trade 69 Vert Barracuda
4spdragtop
Ontario Parts Unknown
Hi all, I have the 69 posted as a pkg with the 67 in another thread, but
Im willing to trade/sell the 69 by itself also. I simply dont have space/time/energy for both cudas. And the 69(1 of 34) deserves better.
That being said Im willing to entertain trades. Boat(aluminium, fish n ski?)/motorcycle, even another mopar?
No projects please.
69 S vert. 340 4 spd buckets console. Have orig fendertag, A53, on it, I had it professionally reproduced. The 340 is not numbers matching, but is a complete 69 carb to pan with x heads, correct carb, bracketry etc. 340 needs rebuild.
Numbers matching 4 spd(good to go) and 8 3/4 rear end(good to go)3:23 gears.
Car is complete with new AMD pans, inner fenders, complete floor pan, and trunk pan.
One fender is NOS and one near mint.
Factory tach with upgraded electronics. 150 mph speedo with trip. Black dash pad in very nice shape. Inst bezel I did a diy resto on and it came out good. No cracks/breaks. Am Radio in nice shape.
Orig 4 spd shifter and handle, console. NOS boot. Interior complete and was recovered in diamond tuck back in the 80's lol. But its all complete and in good shape.
Car is all there, grilles, tail lights, Power top(needs recovered).
Car needs some welding finished up on it, but nothing major, and as I said mostly complete.
As I mentioned, I will entertain trades, but no projects.
$14,000 cash. Trades negotiated.
2 hours east of Toronto Ontario. May be able to deliver to border.
Thanks
Steve
Here is a partial parts list I compiled. Sorry for the long list, I copied and pasted from a MS word doc.
As mentioned open to trades. Maybe even another mopar, I just dont have the space/time to do this to the level it deserves.
Thanks
69 Barracuda boxed parts
1A
Kick panels
Emblems
Defrost hoses
Ashtray Mint
Radio
Steer column bracket
Steer column cover(plastic)
Defrost vents
Ign switch cover
Steering column spacers (plastic)
Steering wheel adapter(NOS)
Heater control and cables
Instrument cluster and screws
Seat belt clips
Blower motor resistor NOS
Pedal dressup NEW
Firewall gasket kit NEW
Rear sill plates
Vert top latches NEW repop
Bulkhead connector
1B
Variable speed wiper switch #2770378
Gauges, duplicates of all 4
Circuit boards in great shape, 2 complete sets
Seat hinge covers, MINT
Glove box door and MINT trim
Wood grain decals for 4spd console (NEW)
Heater controls and cables, 2 sets of controls, 1 set of cables
4 speed console screws
Key blanks NOS
Wiper wash knob NOS
Dash screws complete
1C
Brake pedal bracket(blasted and painted)
NOS brake pedal bushings and clutch pedal bushings #2467771 and 2883482
IE
Emergency brake assembly
Steering column bracket(underhood attaches to firewall)
Hood latch hooks
Wiper pivots
Windshield wiper squirters and clamps
Battery hold down rod
Steering column\brake bracket(under dash)
Fuel tank straps and hooks
Rear window brackets
Gas pedal and cable
Gas tank gaskets(mount in trunk)
3 wiper motors
Heater hose aluminum strap(under hood and original)
Bypass hose for intake
Heater core firewall bracket
SB air breather hose
Window hardware
Power steering pump and gaskets for rebuild
Power steering pump bracket
Seat belt bolts
Trunk lock latch(2 of)
Windshield squirters(MORE)
Body plugs\grommets
Hood support bolts NEW
Underhood strap kit NEW
Heater core hose bracket gasket, NEW
Inner fender gasket/shield new
WD
Window regulator hardware(aluminum pieces)
BA(in shed)
Rad core spring holder bracket
Support for above piece, to core support bottom
Horns 2
Strut rods
Master cylinder(standard brakes)
Battery tray and brace(blasted and painted)
Box of 4spd clipsrods/pieces
4 speed stuff, NEW from Brewers(small stuff)
Engine bay hardware/suspension bolts
Suspension bushings NEW
Exhaust pipe flanges
WD(in box EE)
New front vent window seal
Door handles INNER RECHROMED
1 window crank handle
White plastic window clips for door glass
Rear window felts NEW
Miscellaneous door hardware
Box of door stuff\hardware(window cranks and spacers, hard rubber door end seals, door lite switches, convertible door wedges, door and window hardware)
Emblem nuts
Grommets
EE
Inner splash shields(metal, mint)
Shock plates and u bolts(Blasted and painted)
Front leaf spring hangers
Vent tube for fuel line
Old fuel line(rear pass side)
Fuel fill tube gasket(trunk side)
Dog dish hub caps
EA
Flip fuel cap
Honeycomb for grilles NOS
Back up light housings complete
Trunk latch
Grommets
Harmonic balancer hardware
Fender bolts
Wiper arms
Turn Signal lights MINT
Lens
Stainless steel trim
EB
Tail light lenses and hardware, VERY NICE
Plastic splash shields (3 of them, 1@2800658 and 2@2800659)
Exterior door handles, MINT
MB RONA
PS pump pulley
340 Hipo exhaust manifolds
Original starter
Orig 67 water pump( NOT INCLUDED)
340 Water pump/fan pulley
Orig +ve battery cable(poor shape)
Coil bracket
Orig 4spd throttle bracket(no kickdown pin)
EC
Convertible boot, original will need replaced
Convertible top pump motor
Chrome trim for convertible
Fuel tank sender(original)
Lock ring for sender(NOS)
Grommet for fuel fill tube
ED
Seat belts
Convertible sun visors
MC
Rear convertible window regulators
Door hinges
Sill plates, rear carpet
Crank pulleys, 2 of them, 1 single groove, 1 double
Hurst shifter boxes, 2 of them
Engine fuel pump cam, NOS
Cam retainer plate
My interested list for my 69 Fish convertible.
Shipping to PA. 17111
front 69 fender fish
inner chromed door handles
Convertible beltline trim end pieces
