free magnum block..
dodgethis12
Rating - 0%
0   0   0
I have a 318 magnum short block from a 99 truck. The block has 4 broken rods and a toasted crank. The cylinders look good, no visible wear (89,000 miles). One of the broken rods did take a chunk out of the very bottom of one of the cylinder walls about the size of a nickel.
Its of no use to me... and really should be used for the block. I just figured one of you guys might want it for some reason before I can it.
Im 30 miles east of Richmond Va. First come first get..... This is the shortblock only. No heads or accessories.
804 -five one four- four two four eight you can call or text me- I dont get on here often to check msgs.
Thanks
does anybody want this before I toss it? Useable magnum block....
would you be willing to ship the rear main? i just need the rear main cap is all....
I can do that if nobody wants this. Last chance for a free magnum block... its going to the dump this week....
