I just replaced this with a Ford 8". I don't have a use for it. It is complete end to end and worked just fine. 2.76 ratio. Weeps oil at the gasket. No e-brake cables. I originally pulled it off a '74 Dart Swinger. Most of the brake parts are only a few thousand miles old. One spring perch broke off the housing when I was removing the u bolts, but it would be easy to reweld. Pick up only.
