[SOLD] Freshened 318 - ready to go
swing69
I’m just an old guy……
Central NJ
1984 318 from a 70K mile 5th Ave.
Engine was diassembled and cleaned. new rings, main bearings, rod bearings, (cam bearings were perfect), (all bearings are standard) new oil pump, Summit 6900 cam and lifter set, new timing set with mopar tensioner, new freeze plugs. Heads stripped / cleaned valve lapped in (not cut).
Painted Chrysler blue, has stock valve covers. No intake or exhaust manifold, no distributor.
PU in central NJ. $950
engine is ready install and run. Mild build for street car. perfect for an early A body. I have a set of 273 stock manifolds for an early A body available if you need them (blasted, cleaned, painted)
I have a 64 Dart pb auto with its original 273 that is tired. How about $450?
How do I know that this engine will run well once it installed? Guarantee?
When was it rebuilt?
picts. I wrote 85 on the tag, but its an 84 for sure. if that makes any diff.....
Hi Dan, yes, I still have it, but I MAY need it now. I'm finishing putting together a LA 360. I need to figure which one I will put into the 65 Dart, the 318 or 360......
anotherwords, I don't know what I'm doing. shoot me a PM with thoughts
man I wish you were in Southern California I would buy that RIGHT NOW!
Good Luck on your sale man!
