Front 10" Drums to Rear?
khughesprime
Seagoville, Texas
I got a 74 Dart with a slant now but I would like to convert the front to disks. Can I put the 10" drums on the rear to replace the 9" ? EVENTUALLY I would like to put in a V8 so I am preparing towards the future. Thanks
Anything is posible if you want to spend enough money but practically no. Even if you removed the hubs previously mentioned the 10" drums are wider than the 9" drums so the rear axle spacing will be to narrow for the drums to mount onto the flange of the axle. Also, you would need to get a backing plate the front ones won't fit.
