Sep 4, 2011 #1 S slx70 Well-Known Member Joined Jan 17, 2011 Messages 82 Reaction score 13 Location ohio I have a 1970 dart that had a 6 cyl. with 9" drum brakes in front. my question would be. I have a set of 10" baking plates and drums that were off a v8 car, can i swap them while useing the same upper control arms from the 9" set up?
Sep 4, 2011 #2 805moparkid Slant and AFX Guy Joined Oct 29, 2008 Messages 11,498 Reaction score 289 Location Anthem AZ no you need the whole spindle... the bearing sizes are different from the 9" spindle to the 10" and early 10" spindles have the small ball joint so then it would be a no but if you get the 73 and up brake parts yes you will need the upper control arm for BBJ
