[SOLD] Front door and rear int black and woodgrain panels 73 Duster Dart Sport
Moparparts
PA
FOR SALE: Set of front door and rear interior black and woodgrain panels. These were used with the A88 code interior decor package.
The driver's side front door board and woodgrain are nice used. The black vinyl is coming loose on the bottom edge, and it has a small crack in the center about an inch up from the center and cracks on both bottom corners.
The passenger side front door board does have pieces missing from the lower center clip mounting areas. The woodgrain area is in good used condition. The black vinyl is coming loose at the bottom and has some cracks on the bottom.
The woodgrain rear ones are 73, but the lower area of the boards could be cut out for 74. The left rear board is in very good used condition. The left panel is nice, only one small split and drill hole on the very bottom edge.
The right rear woodgrain panel board does have a piece chipped out of the one bottom clip provision and one hole drilled in the bottom of the panel.
Price for the set of 4 would be $115 plus shipping from Pa 17086. Post or message if interested.
