[WANTED] Front Passenger Door Arm Rest - blue
I have one, but not in blue. You could dye it, or if you just need the base, you can transfer yours. 68-72 are different.
Got these.
The blue one furthest to the left, beside the tape measure, so when mounted on the passenger front door, the ash tray is to the back. Not sure if the rearward position is the OEM positioning of the ash tray, but that's the orientation of it on the driver's door.
Seems it would be more ergonomically friendly if the ash trays were mounted towards the front, but if I have two opposites, I can switch them around.
I have this pair if you are still looking. Had a hard time with what you wanted to do as far as the ashtray placement. One looks like it has been glued to keep it from cracking further around the mounting holes.
What all do you want? Found the other side rear armrest with the ashtray hole if you want that too. It needs to be re glued on the one side. How about $15 for all of it plus shipping? PM me if you are interested.
