Front Side Marker
1971Kyle
Member
Oregon
I can’t seem to figure out how to change out the bulb on the front side marker lights in a 1971 Dodge Dart, any ideas?
I think you just pry it out of the hole. No turning, just in or out. But maybe you turn it a quarter turn
If its like a 71 Demon, which I would imagine it is, you have to undo the 2 nuts on the back of the light inside the fender. Take the light off the fender, undo the 2 screws on the back, Phillips head, the amber lense comes off the front of the light, then just twist the light bulb out of its socket. Spray it good with WD-40, might be rusted in there use gloves so if it breaks, you dont get glass in your fingers.
