Front Track width with Wilwood kit
joes68340s
Rescue CA.
Anybody who has installed a wilwood disc brake kit. Can the tell me how much there track width increased. Thanks
I didn't measure it before I installed the kit. I really don't think it made much difference at all. I can send you a front end shot and you can compare it to your car. Jeff
I made measurments before and after on my 65 Cuda. I went from 9" drums to 10" drum spindles for the Wilwood Disc's and I went 3/8 of an incher wider each side for a total of 3/4 wider track.
I gained almost an inch wider on each side when i switched from 10" drums to 73+ disc brake setup.
Anyone use the SSBC kit on 10 inch spindles. And what was there track width gain. Thanks
Joe you don't gain any real width. I didn't take as acurate measuments as I did on the Cuda, but with the wheels just hanging on there bump stops We only noticed an 1/8" wider.
BTW, the SSBC kit is very complete, from prop valve to Master Cyl.
