Funny thing about engine to transmission struts between 318 and 904...
Trevor B
Novato, CA
I learned something new today.
The left side transmission-engine support strut on my '73 Duster, which bolts onto the bell housing and also to the lower middle of the block, appears to come in two lengths. On this 1983 block, there are two holes next to one another to bolt into, one closer to the transmission and one further toward the front.
It would appear that the 1973 factory 318+904 combination uses the back hole but a 1983 318 (hooked to either a 904 or a 727) uses the front hole.
So guess what I didn't think to check before dropping the engine in and attaching everything I could? The front hole was threaded but my strut only reached the back hole.
The first funny part ways having to go back: off came the starter, transmission cooler lines (the front one of which, by the way, is an absolute bastard to tighten), whatever else is in the way and in went the tap, sort of.
The second funny part was me trying to tap the hole upward, upside down under the car, using various means of turning the tap to work around the oil pan, exhaust pipe, etc.
Yet another fun fact to put in my notebook.
Sorry about the above. Chrysler increased the length of that left strut-brace on the 76 360 and then on the 81 318 for a longer starter. On the 904 for sure, probably for the 727 also.
I remember running into this issue once, I removed the ones from my 360 to install the dougs headers and them put them up for sale here
a fellow member bought them for a 340 (I believe) and they didn't fit)
I seemed to remember reading after the buyer posted for advice here that they made changes between the 318-340-460 and different years
