Gas cap
plymouth71
The Moomobile
London ky
Hello,could anybody tell me which gas cap came stock on a 1971 valiant scamp,vented or non vented?Thanks
Does your fill tube have a metal tube running down into the trunk floor? IF so,it's non
Just have the fill tube,no other,just curious would the cap make much difference?Asking because I really haven't considered the difference between the two.Thanks
The non vented cars used the filler in this pic with the small metal line exitring the trunk floor at the seal. If yours doesn't have that or the nipple for it then you need a vented one.
It may cause vacume to build in the tank which may cause other issues
