I was reading an old thread on engine size and gas mileage, instead of bring it back from the dead I'll put my thoughts here
1st thing, lets assume for now most engines have same efficiency, it takes the same amount of fuel and air in a given amount of time to make a certain hp, (thats why hate the miss use of the phrase "No Replacement for Displacement" if anything it should be no replacement for bore size) but anyways.
2nd the cars performance should be decided even if it just enough HP to drive the car down the road at highway speeds and safely pull into traffic, but to me the minimum hp an abody should have is 200hp I always find peppier cars better on gas for me since I got a heavy foot . Most cars need 50-70hp to drive at highway speed (dependent on aerodynamics, weight and speed) so a stock slant six is barely adequate at about 110hp, so the minimum rear gear you can get away with is where your engine makes 70ish hp (remember it takes the same amount of fuel to make 70hp whether its a slant six or a 440 so either should get the same mpg if you could find high enough gears for the 440 but it would have acceleration of a /6). A 440 is gonna make it closer to idle where a slant six will make it closer to peak power. Gearing is the great equalizer when it comes to different displacements whether its performace or gas mileage.
Speaking of displacement and performance (hp) and gas mileage you probably want 0.7-0.8hp per cid cause for good mileage you don't want the peak power to high in the rpm band and anything under 0.7 hp per cid is pretty inefficient engine.
Energy can't not be lost or gain but only transfered from one state to another, no free lunch
Every mod you do to your car has trade offs, if you do it wisely you can get close to having your cake and eat it to. So I guess what im saying if built efficiency similar performance is gonna get similar gas mileage if built right whether you build a 273 or 440.
P.S. I got a 1980 Bronco that im fixing up hope to have it back on the road next year, its got a 400 in it and got 10 mpg when I parked it, I bought headers and performer intake and carb and went with a Comp 256 cam, could of went to 262 or 268 with out sacrificing any bottom end and gain 20-30hp and 500-1000 rpms but my truck will rarely see north of 4500 rpm and even a lost of 1/2 mpg over the 256 cam to me wouldn't be worth it.
