360duster
Hi Guys,
i´m trying to help a guy getting a Hemi back to life. this Engine was in a 68 Charger, owner is not able to do the maintenance.....so to me it seems the engine ran several thousand street miles with a lot of valve lash (solid roller cam, some checked around 60 thousands cold now). During an oil change he found metal in the oil and stopped using the car. I found one lifter and the cam lobe damaged, the main and rod bearings look acceptable to me. It seems that no trash went trough the bearings / Cylinder walls.
So i´m a SB Guys, sucessfully built a RB Wedge before...but have no clue about the Hemi Stuff.
Are Camshafts Hemi specific or could any B/RB Cam be used? Same with the lifters, could any B/RB Lifter be used? Since the car is intended to be driven a lot, would a hydraulic roller cam be a good option in this case (low maintenance is key, no racing intended)? the owner is kinda special, i´d like to give him the least amount of things to think about, that´s why i´m thinking about the HR Cam.
Thanks for your feedback!
Michael
Michael
