[WANTED] Glove box spring 65 valiant/barracuda
Patrick
Olney, MD
Putting my 65 valiant conv back together and noticed i'm missing on the springs (need the left side one, not sure if they're interchangeable).
Not sure what other years might fit either.
Thanks!
Patrick
Hey Don! I'm finally getting back on the 65 project (you sold me the K member?)
I will look at my glove box door and mechanism more carefully - it sure looked like something is missing on the driver's side to hold the door up...
Hi Patrick - yes on the k Frame. If I’m wrong on the spring, someone more knowledgeable than me will surely chime in!
This is 67 Dart spring, does it look anything like this? No spring from 68 up, so it might be a holdover from the early As
It is also in the right side.
Yes, looks just like that but the mount looks a little different. The spring looks identical though. And from a quick visual it also looks like the spring would be the same left/right. Here's a pic of my pass side one.
There is only one spring on the right side. Section 23-6-21 and 23-06-22 list the hinges and spring part numbers. All the same from 63-66. The 63 book lists the spring as going on the right.
So I have a part missing on the drivers side then! Can someone post a pic of what the hinge area looks like on the drivers side?
Appreciate the info!
Patrick
