chrisnben
MR Badfish
GM 700r4 Overdrive Transmission built to handle 700+HP. Brand new from PATC "Mega Raptor" kit including billet drum, billet input shaft, etc. Forward pattern 4 gear overdrive, deep fluted trans pan, PATC torque converter- stall 2500-2900 (depending on your engine torque). Also have the Lokar kickdown TV cable & B&M shifter plate (for O/D)- included. Also have the Wilcap billet aluminum adapter plate & flexplate for Small block Mopar (which was $610 alone). Wilcap will swap my adapter for a BB Mopar one for the cost of shipping- if needed.
http://www.transmissioncenter.net/700MegaRaptor.htm
This trans has never been run since built. I sold my car project. Taking a $1100 loss. Also, save $1000 over these other companies wanting $4500+ for their O/D units.
The trans mount is very close to a 727, just drill 2 holes in the GM mount- uses your stock X-member. Plus the 700r4 will fit into your trans tunnel easily.
$3499 includes everything. I can ship it for $175 in the States Here's a stock photo-
