Gonna bite the bullet
AdamR
Big Member
Bethel, CT
I think I may sell my magnum heads and save up for a set of edelbrocks.
To use the magnums I'll need springs, retainers,locks and seal, A valve job, slight mill to clean them up, machining for retainer clearance with my cam. and a intake. About $800 when done.
I could swap on some new springs and hope for the best but I'll end up kicking myself in the end. And If I went with a smaller cam I wouldnt have to machine the guides down.
Another $600 gets me the Edelbrocks.
The car goes in the garage this weekend.
I figure if I sell the magnums heads it will only cost me an extra $600 to have a much better head to start off with.
Where do you see Edelbrock heads for $1400? When I got mine I think I paid either $1100 or $1200 for mine from summit. I went through the same thing thats how I ended up with Edelbrock heads also. For a stock rebuild, nothing fancy, of a pair of J heads all the shops around here wanted $800 also.
Thats including the ARP bolts and gaskets to put it together.
I still think the Magnum heads are the way to go for a milder build up but I think it wont take long for me to out grow them.
This is true! I don't think I even have 2000 miles on my motor yet and I have thought of some stuff I would like to do to it allready! :)
Same here.
Same here.
Fast cars are like crack except, its only my wallet that seems to get buzzed! :lol:
Tony get that motor dialed in so I know what mine will run. Im pretty much building the same motor.
What kind of compression are you running?
