Green dash pad, kick panels, visors, column cover, a pillar trim
ESP47
Sacramento, CA
Dash pad has some cracks in it as you can see pictured. Not horrible but not great either. $20
Kick panels $10
Sun visors $10
Column cover $5
A pillar trim (one hole has chipped on the inside) $10
Pair of dash vents $5
All of a 73 Valiant and in driver condition. I've taken pictures of most the blemishes so you can see. Prices don't include shipping. I'll combine shipping if you want multiple items. Located in Sacramento CA.
Arm rest bases are $5 plus the ride for all 4. I believe one or two might have broken tabs on the back. I'll have to check and make sure.
Evan, I'm pretty sure the dash pad, kick panels and column cover will work. If the A pillar trim pieces fit, they are going to be a bit different from the stock 68 Cudas. The sunvisors I'm not sure of.
Kick panels $10
Sun visors $10
Column cover $5
need the a pillar trim and the steering column cover
