[FOR SALE] Griffin 22” Exact Fit Radiator 5-70027 (USED)
68ss
Member
San Jose, CA
Rating - 0%
0   0   0
Griffin 5-70027 exact fit aluminum radiator for sale. This is a lightly used 22” radiator I had in my car for a few thousand miles before converting to a 26” rad after I built my big block 451. It still cooled the 451 fine but I wanted to upsize to 26”.
Be aware that this is 3” overall thickness. It is a 2-row with 1-1/4” tubes. It cools awesome. Both inlet and outlet on driver side. Has built in transit cooler that can be connected or bypassed. Does not include rad cap. Will ship in box I received my 26” griffin in.
Be sure to measure your clearances from fan. If you have a clutch fan setup it may be tight unless you use the low profile neck Hayden fan clutch. Full Mechanical or electric fans should fit fine. This is an exact fit for an A body 22” but I also ran it in my B body. I’ve included screenshots from summit’s website for all of the detailed info.
I also have a plastic repro fan shroud that bolts right up to this. Please note that the fan shroud fits the radiator, but has fan offset to work with a B-body car. So I better post the shroud instead on FBBO. I'll still sell you the shroud if you want to try it or if you have a B-body or C-body.
Radiator sells for $743 new.
Radiator $385 OBO + shipping
Fan shroud $100 OBO + shipping
ships from Northern California zip code 95127 or local pickup to lower 48 USA.
happy to answer any questions:)
